-   -   Megasquirt anyone ? (https://www.germanlook.net/forums/showthread.php?t=10057)
cookiemonster May 31st 2009 02:43
Megasquirt anyone ?
Hey eveyone,
has anyone used the Megasquirt systems with turbo or superchargers?
and if so what system did you use/
I want to surercharge or turbo my 1914cc type one I have both a magnaflow supercharger and a garret t3 just don't know leaning towards the supercharger:bricks:
any input would be great thanks super freaks:goodjob:
NO_H2O May 31st 2009 10:32
We built a 1915 type 1 with T3 turbo, Megasquirt 2 and other assorted goodies. Still tweeking on it when we time (customer stuff comes first). So far we are very happy with the MS2. When we are done the ECU will control Ignition, Fuel, Boost, Alki Injection, Oil Cooler Fan and Knock Sense. We have done a few SDS systems in the past and wanted to try the MS2 as it has more control. So far so good.
cookiemonster June 7th 2009 13:10
Hey NO_H2O,
i had a look at that project SWEET is all that i can say :cup1:
do you have the specks on that engine as in the size injectors and so on also where did you get that bracket for the pickup on the fire wheel?:thumbup:
and can you please post more photos.
thanks again.
Cookie
NO_H2O June 7th 2009 15:15
I think we used 48 lb injectors. The bracket for the pickup was made in house. the Turbo is a Garret T3, intake system is a stock injected VW set up with CB FI end castings. A Bosch TPS was fitted to the VW 45mm TB. As for the internals, the long block was built by Chico Performance Racing.
cookiemonster June 8th 2009 03:03
Hey NO_H2O,
can oyu make me a pick up like that please:notworthy:
and give me a price?
thanks,
Cookie
NO_H2O June 8th 2009 12:30
I will ask Kevin if he can do another and how much. I will have to match your pulley/trigger wheel, or do you want that too?
cookiemonster June 10th 2009 04:29
Hey NO_H2O,
can you do it all and PM me with a price>
thanks again
Cookie
