Stroker Crank Question?
Hello again from the Nordic Empress!!
I was wondering what is the maximum stroke for an aftermarket cam that is available which doesnt need any machining to the stock 1600 case?!?! Thanks for the info!! Clint |
Not sure if I am reading the question right, but for no case clearancing a 76mm stroker is the biggest you can go before having to trim the case... Granted you still might need clearanced rods for this setup.
Thanks that is all that I needed!!
By the way what would be a great clearanced connecting rod? Thanks and you did read my question right!!! Clint |
What I meant to say in my first post was aftermarket CRANK, I'm just slow!!
CB's got some nice CroMo I beam rods, with bolt bosses trimmed for a stroker crank. Set of four sells for around $100.00 We got a set for Hummbug and I was impressed with the quality and light weight. Especially for the price.
Yetibone P.S. These rods are for a T1, not a T4. |
| All times are GMT -4. The time now is 00:51. |
