There is nothing wrong in using the Beetle bearings.
All big Porsche kits from Germany are based on the Beetle bearings. They are inexpensive and I believe from the same manufacturer SKF.
The Kerscher vented front disk brake uses Beetle bearings.
So it really does not matter which way you go.
My 993 Twin Turbo kit uses Beetle bearings.
It all depends on if you want to machine the hub or not.
