View Single Post
  #19
Old October 14th 2009, 17:06
buggyboyshane buggyboyshane is offline
Originally Posted by jmd View Post
I hear that the solution to this is to bend the arm. But I am using the 901, with a (Currently) stock cable and it works fine. But I am about to convert all that to a custom pendulum pedal setup so my configuration will change.
i was using 901 one and needed to bend the arm and grind some of the hook away to let it slide past the frame horn, all worked perfect!!
