View Single Post
Old February 17th 2012, 17:28
owdlvr's Avatar
owdlvr owdlvr is offline
Wow, where has the week gone?! My best friend is back in town, after being gone for six months, so I haven't been getting as much work done on the car as I would like. A sacrifice I'm willing to make though :-)
I have got a bit of time in on the car, but not a lot of exciting work done. When I originally ran the speedometer sensor wires, I knew I was going to need to run a second run though to transmission area. I was able to make up the second harness I needed, and drop it in.
Almost immediately after running the wires through I realized I had forgotten one. Doh! I considered pulling out the harnesses and adding a few more wires to them, but then realized I would probably end up one wire short down the road anyhow. With that, I figured I would put a third set in, with three times as many wires as I anticipate needing. When in doubt, build for expansion!
Also worked on making some of the harnesses I will need to install. Oil cooler fan, oil fan thermostat and reverse light switch.
...and bought the bits I need to make the turn signals work in a late model. Should be back to regular work after the weekend!
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
