View Single Post
Old April 10th 2012, 18:02
My bugs in a million bits now....im trial fitting my ally arms, i have removed the wings, all the metal arms etc.
im looking to make a sleeve in delrin to slip in a urathane bush and hold the spring plate off by 6mm ish as i have read others have used spacers to get past the large bolt head on the spring plate (is welding it an option i thought it a bad idea on a spring plate?)
its hard to tell if the toe is an issue, i have taken a bit off the rear springplate bolt holes to allow me to slide the arm forward more if needed.
i dont seem to have the springplate flex either and im considering spacing the 944 cover off 6mm also. i had one large washer inboard on the alloy arm
i didnt even think of handbrake cables.....i presumed my ones would fit, silly me when will i learn.doh another issue, i had the existing ones made up so i guess i will have to get some more..
