View Single Post
  #127
Old November 30th 2013, 21:30
H2OSB H2OSB is offline
Watched the video closely because I like the suspension parts you make. I noticed you did away with the holes in the tubular control arms (where the sway bar used to pass through) in favor of a heim joint mount. What sway bar are you using?
btw...If you don't want the old control arms anymore....
johnL (aka H2OSB)
