I’d say the head studs can handle way more then you’re now, but its the stock heads that trend to worp a bit, causing leaks.
Even stock engines saw this problem. Especially buses..
Anyways, never torque the head studs more then stock in an attempt to make it seal “better”. It gets worse with more torque on the head studs then stock torque settings.
Thought I’d mention that again, for others that might be tempted 😉
