View Single Post
Old October 17th 2019, 04:43
Originally Posted by CarreraLook View Post
Hi all, I've just bought an early '74 1303S/Super Beetle with the 2-bolt upper bearing assembly (but not the rack-steering), which also has the 20mm-each-side wider track. I'd like to run it with Fuchs in 6x16 ET36 and 7x16 (not sure of the ET) but the fronts aren't going to fit without sticking out and rubbing on the wings, especially with a modest 2-3" of front lowering. By my estimation the fronts 'should' be ok on the back-spacing but will stick out around 1" (25mm) more on the bodywork-side.
So the question is, how have other people done it? I've heard that the 3-bolt assemblies can run in the 2-bolt cars (but not vice-versa), but would this also narrow the track to the earlier dimensions? I'm no mechanic - but I'd like to reassure mine that it can and has been done (I see lots of photos of late SuperBeetles running the same set-up). Do you also have to swap control arms, swaybars, spindles, etc... is there an easier way?
Any advice?
I have an 73 sb (curved screen) with 3 bolt setup. I have cookie cutters (6x15, et36 and 7x15 et 23.3). But the fronts is catching the lower springcup.
Therefore, i purchased the Kerscher coilover set to clear some space. This will give me the clearance i want and do not have to use spacers. I can stay under the standard wings.
So you can go back to the 3 bolt setup, but then the wheels would catch in the lower springcup or even the spring (with the 16"). So the need for the narrow coilovers are a must.
Or you stay with the 2 bolt setup and purchase some wider wings.
But correct me if i'm wrong.
