View Single Post
Old March 23rd 2021, 15:51
Blizzard's Avatar
Blizzard Blizzard is offline
For the first time I have over 200 horsepower in my car.
To bad I can only use half of it at once.
When everything was bolted on and connected again, it started on the first try, and runs perfect. I have no photographic evidence it was to dark.
AFR is in the high 13s at low and high rev's with the current jets. I think I will only change the accelerator pump jets from 33 to 35.
When I open the gas quickly on the test stand it revs up without running lean with the 33"s. The first time in the car, it ran lean while accelerating with the 33 accelerator pump jets installed.
venturi 32 try 30
main jets 125
Idle jets 52 try 55
air corrector jets 180
emulsion tube 9164.2
accelerator pump jets 33 try 35
Now I want to install the engine asap in the car and start finetuning with the DRLA's under load and with a warm engine.
I also have a set of italian 40 IDF's I want to test
