I replaced the trailing arm bushings and added some length to the slots in the adjustable spring plates so i can get to 0 toe. I installed the left cup brace segment but will have to cut and re-weld the lower/aft tab for the right side. It fit with the dummy engine but the stroker engine has the exhaust too close to the down rod on that side. I think I will have to drop the exhaust to cut the tab free. Put it back up to tack it, then pull it back down to finish the welds.
