Thread: 225/40/18
View Single Post
Old March 3rd 2011, 09:00
evilC's Avatar
evilC evilC is offline
Wally, I think that your analysis of the relationship between springs and damper is right but I think the starting point is 'why have springs?' The spring isthere to allow the car to maintain an even keel across any bump/hole. It needs to be soft enough to allow the wheel to follow the road surface that is hard enough to stop the wallowing and soft enough not to be thrown in the air. The damper is there to moderate the rate at which the spring reacts, too hard a setting means that the bump energy is transmitted to the chassis that can be upsetting, too soft a setting allows the wheel to overtravel and lose traction.
The adjustments on a damper are there to fine tune the spring reaction, mostly in rebound and that is a function of the speed of travel and the type/magnitude of bump encountered. On a billiard table smooth but of tarmac the damper shouldn't be necessary at all.
