Making up an access panel for the offside rear inner wheel arch
Engine and trans in! You can also see the inspection panel in place..
I welded up an adapter for the clutch slave pipe. It was an M14x1.50 thread and 8mm pipe which I thought was very big, I've decided to use normal brake pipe size so had to adapt down to M10x1.0 and used a spare brake flexi pipe I had.. It is all kinked over a bit to get extra clearance to the exhaust downpipe. If it turns out to be too restrictive I can easily go up a size later on.
New turbo coolant pipe hardline was made up and bolted on to the top of the bulkhead to neaten things up a bit.
The thermostat bypass will be used as the heater supply in my installation so I made up this adapter to go down to the smaller pipe size.
It's just a long list of time consuming little jobs from now on! Gutted to hear that Le Bug Show at Spa Francorchamps isn't going to be on next year as that was going to be the debut, I guess I'll have to find something else...
