ccain529
Powdercoating is the way to go, especially if you are doing a keeper. ( I know, they are all keepers...)
However, from what I understand the pan must be super clean. No seam sealer, no rust, no nothing, just a bare (litterally) pan. Prepare to spend some quality time in your garage, just you and your wire wheel... You will most likely get powdercoating in all the bolt holes, so you'll have to run a tap through to clean them out, but no more than if you had painted the pan.
The other thing is to see if you're local powdercoater has a oven big enough to fit the pan in. Some do, some don't, you're might...
Doug
