Originally Posted by Humble
Great build overview and pictures. One thing you might consider is relocating your oil pressure sending unit. If that is an Autometer piece, they don't seem to like vibration -- at least mine didn't. I ended up remote mounting mine under the parcel tray using a feed line off the tee (same as you did for the turbo oil feed). I've seen other mounted on the firewall or on the side of the engine bay...
Kafer_Mike
