I was hoping to have the motor in the car this weekend but delayed parts prevented that. The new motor is all set though with a few finishing touches...
Rebuilding the motor didn't take very long... because I forgot to take pics :P With the heads and barrels off wear was minimal. There was minor evidence the heads had lifted at one point, 31psi will probably do that. Other than that, rockers looked good, no excessive wear on the lash caps, push rods were still round, and so too were the barrels. Before tearing everything down though I measured the lift at each valve and compared it to my build notes. The results were .002"-.003" of wear across the board, not too shabby.
I started putting some new parts on, which was in an earlier pic, a new ultra wide glide sump to replace the thin line sump, and a fancy jaycee o-ringed drain plate.
The front of the case got a new 30mm oil pump with full flow cover, new stock size billet sand seal pulley with new seal, and AN -8 fittings for oil feed and return.
This is what .015" deck looks like
Something I said I would do when I had the motor apart was to grind the corners down on the fuel rails so the injectors would sit off to the side. That way the don't get pinched between the manifolds and the shroud. I also swapped out the 750cc injectors for 375cc units, no need for big fuel without a turbo.
Here's the motor back together and ready to go. Manifolds and TBs are just set in place since they need to come off before the motor goes in the car.
Final build specs on the motor:
2176cc, 9:1 CR
CB 1157 Alu race case, +3.5mm deck, german pickup tube
CB 2668 Super Race Crank, 78.4mm, chevy journal
CB 2666 Super Race Rods, chevy rod journal, 5.7"
Mahle Forged 94mm pistons, with coated skirts, 94mm stroker (extended) barrels
Coated main bearings, and Clevite rod bearings, anti friction coated
Cima/Mahle 94mm rings, Total seal 2nd ring
CB 1223 Cylinder Head Studs, 10mm Chromoly
Eagle Racing K-8 cam, Adv. Duration 308*, Dur. @ .050" 256*, Lift w/ 1.3 rockers .491"
CB 1849 Camshaft Bearings, anti friction Coated
CB 1537 28mm Ultralight Lifters
CB 1399 Straight Cut Cam Gears
CB 1421 044 CNC Mini Wedge Port (42 x 37.5) 94 Bore, K800 springs, chromoly retainers, 65cc, .015" deck
CB 1575 Forged 1.3:1 Rocker Arms
CB 1629 Chromoly Dual Tapered Push Rods
CB 1515 Push Rod Tubes, JayCee Silver Bullet
CB 1702d Valve Covers - C Channel
CB 7366 Big Beef Manifolds with Fuel Injector Ports, IDF, port matched to mini wedge
CB 7356 48mm Throttle Bodies
Precision Injection 36# (375cc) injectors
CB 2017 Black 7'' Billet Crankshaft Pulley with Steel Hub for Sand Seal
CB 2050 Stainless Steel Broached Crank Pulley Bolt
CB 1862 Maxi 30 Full Flow Oil Pump with Black Anodized Billet Cover,3/8'' outlet
CB 1706 4 Qt. Ultra Wide Glide Sump
CB 3200 JayCee Mag-X Magnetic Sump Plate, Black
DTM Type 1 cooling shroud
Compu-Fire Dual Cool 90 Amp Alternator
CB 2182 200 MPH Alternator/Generator Clamp
Killer B welded late model fan
Type 4 oil cooler
