Originally Posted by Chris Percival
The bearing inserts where made on the lathe, then pressed in complete. The bearing spacer is separate as it had to be made from aluminium so it doesn't rust..
Chris,
How do you get repeatable centering with that fixture held in a 3-jaw chuck?
(or is accuracy beyond the 3-jaw not an issue for the machining required on the hubs?)
Bill
