Hey Jim,
Check out my previous posts, and if you want those Speed sensors to work, you just need to check the output if you want the computer to actually know the correct speed you are going. The ecu is expecting to see a square wave pulse, with four pulses per revolution of the wheel. The computer considers one pulse to be voltage decreasing to 0V (below 0.1V or something) and increasing to 5V (over 4.7V I think). So if the speed sensor you find outputs a wave you just need to supply it with a ground and 5V from one of the engine sensor power wires and you're all set.
Mike
Originally Posted by Jim
Hey quys..
Do you think one of those might be work to solve my problem??
I have found from a local shop called "Brantz rallymeters"these two sensors
Which of them is the correct one??
Universal speedcable sensor
or this
Japanesse Gearbox
Price each is 50euros.
Thanks in advance,
Jim
