If I could make a suggestion, if you'll be pulling the motor several times you should install quick-release sleeves on your oil and fuel lines to keep everything clean when you have to pull the engine for maintenance, etc. Kind of like this, similar to an air fitting line on your compressor:
'66 Bus(11-window, CLK rims, disk brakes, IRS, bags, hydr. clutch, Super-1600 w/injection)
