That's ok Trogdor. It really doesn't matter that much. I can see that you will have
major rubbing issues already when you get that thing on the road. The rear tires protrude outside the finder lips and when they bounce, if you run any rear suspension,
you will rub!!!
The turning radius on the fronts will do the same.
I'm glad to see that you have proved that you/anyone can mount large rims/tires on a static car. The proof will be when you drive it
Take care and good luck
Kelly (Cohibra45)
