While the header was off and in pieces I took the opportunity to get the die grinder out and do some match porting, apparently this is good for a fair few bhp!
All painted in high temp paint and mocked up on the engine to check ground clearance. The aim was to make sure the oil filter wasn't going to be the lowest point and this looks about right to me...
The original up-pipe lagging was savable so just painted but the rest will be wrapped and repainted.
Manifolds wrapped. I used the stainless ties that came with the wrap but found stainless MIG wire worked better, fitted every few inches.
8m of 2" wrap went into the manifold and another 10m for the downpipe! The wrap was soaked in water first as it later shrinks to a tighter fit as it dries out. Due to the low temperatures at the moment it was taking forever to dry out so I improvised and left the hot air gun blowing down the inside of the exhaust and it worked great!
Additional support made up to support the muffler end of the exhaust. I managed to scrounge enough stainless bar to make a bracket on the exhaust and made up the support using a mini style exhaust rubber mount.
All fitted up. Note I also painted the wrap to stop it absorbing water, oil etc later on..
Quick check to confirm the muffler is not the lowest part..
