I've got the QA1's to fit upside down by drilling a new lower cup mounting hole, higher than the original hole. Make sure you check that the shock does not bottom out before you drill.
I'm now using the DDR4855P model, but still deciding on the spring rate before ordering the springs.
Still need to pick up the correct length lower mounting bolts.
