i was in your situation when i went through my type 4 phase. I wanted a 2270, blah blah. but things can get a bit overwhelming, i just name a few problem areas....
-lifters!
-heads are freggin expensive, with a 2270, the heads will be the weakpoint, so u have to determine how far u should go with headwork$$$$$$$
-exhaust, now that u are at a 2270, and spent $$$$$$$ on those heads^^ u gotta throw down some bills for a decent exhaust, u dont wanna restrict those expensive heads with a run of the mill stock bus exhaust.
If you go the type 4 route, and if i were to go the type 4 route, i would get a stock 2 liter engine, run it til it dies, and put in another used one. The most i would change would be
-carburation
-cams
-home port/polish
-build ur own shroud, using the next gen thing
then when you can, swap the 2.0 heads for 1.8 carburated heads. they have the same outside diameter as the 2.0 jugs.
and if you want to make it even easier, sell the bug and buy a type 3, then you wont even have to make a shroud.
btw, i ended up going the subaru route.....
-Ryan
