I didn't get any pics when I checked crank to bearing clearance, but here's a couple of putting the crank gear assembly together. The oven is your friend during this step.
Crank to cam clearance? no problem!
Put the rods on and checked clearance, but apparently those pics didn't upload. :P
Almost buttoned the case up, had case sealant on and everything, before I realized I didn't have a cam plug
That's it for now, I had to cover it all up until I picked up a couple things. I have to verify this but I might be running a distributor-less ignition, so no dizzy shaft either.
