924 brakes???
The idea of putting bigger brakes to your 67 is ok, but don't use such old 'n small brakes. The discs are only slighly larger and not vented, the caliper is not the best. Even if it's for free, it's not worth building a conversation spindle mount for these brakes.
It makes more sense to use just Type 3 calipers with 42mm pistons and use some drilled discs with 5x130 bolt circle.
Btw, the 924 old brake is original Audi!
