View Single Post
Old May 7th 2009, 13:13
petevw's Avatar
petevw petevw is offline
Looking at this pic, what are the 4 holes all about on the springplate?
The 2 round ones on the left have regular bolts to bolt to the arm. The far right hole has what looks to be a camber bolt with a huge hex head on the inside. Does the middle hole stay empty? Does it need another bolt? I can't recall if i have this "camber bolt" on the drivers side. I'll have to look again. Is the Camber bolt used for setup, and them removed after cranking down the other 3.
Am i way off here?
'72 super
'65 bus
'52 split
