RE: suspension fix
I am looking for very tight crisp handling, while still being plush enough to drive around everyday. Low to no body roll is the goal, (LOL) But say straight cruising like on a freeway is silky smooth, not..."Oh so that's where my kidneys are located".
Any help? I will be changing out the steering system in the car to an RX-7 rack and pinion. it welds right up, or can be mounted, using the stock RX-7 clamps, to the front beam, and then plugs right into the wheels in the stock location. And the steering column u-joint is alot easier to use than the lil VW rubber disk.
