I'm converting to a thermocouple for oil temp because the IC's I use to read the TC's have an error of 0.5 F and their output is linear. No need to calculate or extrapolate the temp from graphs that are provided for a particular thermistor, whose output in not linear with temp.
For AAT and FIT, I'm also using IC's with a linear output but the IC tells the temp accurate to 0.5 F, no TC's here and the IC is the size of a pencil eraser ... very small. FIT and AAT won't get above 50 C and the IC's are very accurate in this range.
The auto-max gauge concept is for me to tell if the heads are too hot when I am racing ... I can always tell which cylinder was too hot when I look at the graphs after the run.
I could have used an LCD on the dash to give me the required information, but I like the look of the gauges ... and I don't want my dash to look high-tech ... I want it to look like VW could have built it in '74
