Originally Posted by Xellex
That's cool, I will also check the code stamped on the tranny. One more thing I noticed: it has a transmision oil cooler, did all of them have that? And do we use it in the bugs or just remove it and close the circuit?
The cooler is an "upgrade" it helps with higher HP engines, or heavy track use. If you stay under 280 HP you shouldn't need it.
