NOooo, with an additional collector before the turbo, I would totally KILL the twin-scroll principle/advantage/idea!!
So, the pipes will remain seperate. I just have to hammer them both into a rectangle at the end
Not necessarily..depends on the collector size and length.If you donīt use a common collector,then the 2-1 collectors should be the appropriate size,to minimize pulses and backpressure.Iīm not saying that is the case with your system,just speaking out generally.Iīcanīt remember where,but I saw a collector that someone made from a Burns collector,it was a 4-1 system with a 4-1 collector that then divided into 2 rectangular pipes to the twin scroll flange.As far as heat retention and minimizing back pressure,I think that would be pretty effective.
