Thread: Wiring Harness
View Single Post
Old November 8th 2010, 21:44
I have used this company for a few "re-wires" very good products, and support. Most important it eliminates ALL the amps from going thru the ignition switch like factory VW harness does. There are a few relays you can't get for the later VW's this harness gets rid of. You can mount the fuse block under the back seat, hood, or stock SB location.
Its the second item on the page, and if you click on the link you can see how easy the harness is to install. The pix are of an early beetle, but you get an idea of how to do it. It comes with great instructions for different year wiring issues to deal with. A wiring diagram of your year car helps alot to "adapt" factory items on the later years.
http://www.watsons-streetworks.com/v...le.wiring.html
