I was looking through aircooled.net's site and I noticed an addition to the description for their kafer bar. Looks mightly similar to my rant a couple of posts (#3, April 28/05) up. Change a few words here and there, but unless you're a bilnd man....
For your viewing pleasure:
It's also important to note that there are copies of this device that are showing up. Most of them use Heim rod ends. Think about this; Heim rod ends are designed to be used on an articulated link (a link that must move). For the Heim Joint to swivel within the socket, there must be clearance ( If there was no clearance, the ball wouldn't move). So from an engineering perspective, it makes ZERO SENSE to use heim joints for a stiffening component. For a link that has to rotate, it's great, but for a link that is intended to be stiff and not move, is is the worst connection you can use. The ACN KCB uses solid clevis ends, which is the most stout and solid connection you can use on your car, and they will not wear or loosen.
http://www.aircooled.net/new-bin/vie...RC0006&cartid=
Hmmm, atleast give credit where it's due. I pride myself of developement. Everything I sell I have personally developed. I've never purchased something and "reverse engineered" a product. I've done it the old fashioned way; the triple-C method. Calipers, Calculator and CAD. It's the only way I'll put my name on something. I haven't yet had anyone copy my product (although I'm sure the future holds many surprises), but to copy my ideas?
JC, I'm calling you out. No hard feelings, but throw some props my way!
