Hi Brent
With regards to fitting the MSD dizzy when I mentioned that you can cut a part out I meant on the left steel strap that holds the fan down.
Made a small schematic to help you out.
Although your shroud and the block that the fan sits on may have been produced in NZ I don't think they differ that much from the ones sold here at Europe. After all they are all pretty much copies of each other!!
Do you have a picture of your shroud and fan bolted together along with 009 dizzy?
Wrt to the quality of the trigger system that CB sells it is very good. Have a couple of friends that use it and they had no problems with it.
Another system you might want to look at is the one from VW Speed Shop in the UK and it's this one
http://www.vwspeedshop.com/product.p...cat=494&page=1
