Guys, check this out.
http://www.demon-tweeks.co.uk/produc...09&tlgrp=MS002 The variability on the top mount should work for both of you. To use the camber plates or strut top mounts (in English) you will need to use 2 1/4" springs to allow enough space to relocate the top mount to give you the extra camber and/or caster and that will probably mean new strut legs with say adjustable plates. It all starts to get expensive and the wrong side of £1K
evilC
