Old May 19th 2010, 08:13
1303bug's Avatar
1303bug 1303bug is offline
what wheels ? comfort and usability
hey im in a bit of a dilemma here ,
im looking at 17" turbo twists at the moment but have been told that the
17" wheels would look super but bugs on 17" wheels drive awfully. Aska anyone with 17" wheels on a bug and they'll tell you.
is this right ?
then i saw a pair of 15" revolutions drilled to 5x130
and was told that
the smaller revolutions are a "standard" wheel that gets drilled for any pattern, hence the big flat area in the centre where the bolt holes are. They'd be grand to drive on as you could get a nice big tyre on but it really depends on what look you're going for and what your priorities are: looks or comfort/usability.
so what i'm asking is which wheels offer style and comfort and are usable ?
i want a wheel thats easy enough to install without huge modifications , im going to be running 944 aluminium trailing arms on the rear and 944n/a brakes from the balljoint out on the front.
Thanks ,
Old May 19th 2010, 09:41
I had no issues at all with 17" cup 2s. It's more about tyre profile and combined wheel/tyre weight than absolute size. Obviously what suspension rates and damping you use will also affect things.. Ally rear arms will increase the track and I'm fairly sure you will need wider rear wings for any porsche wheel..
Old May 19th 2010, 12:22
petevw's Avatar
petevw petevw is offline
No issues with my 17's on the super. Been running them for 9yrs.
Daily driving, drag strip, and the track. A-OK!
'72 super
'65 bus
'52 split
Old May 19th 2010, 16:41
No problem with 17's here, I will say that I run pretty low tire pressures due to the lightness of the car. Definately don't run the standard 35psi, I think I run 25psi or less. Softer pressure = softer ride. Lower profile=less sidewall rollover= better handling feel.
Old May 20th 2010, 10:36
evilC's Avatar
evilC evilC is offline
For day to day comfort profiles greater than 50% are recommended and given an o/a wheel/tyre diameter of 640mm you can work out the tyre that suits you best.
BTW tyre sidewall is much lighter than alloy wheel so that the larger the wheel/lower the profile the greater the unsprung weight.
Old May 20th 2010, 14:03
Another thing to watch is wheel weights, they can vary a lot. Typically repro wheels weighing a lot more than genuine ones... There's a site called 'wheel weights' IIRC that lists a lot of the common ones...
Old May 20th 2010, 18:27
I have 17 x 7s on my daily 1303, rides great with 215/45 tyres. I had 17x8 & 17x9s on my 1302 ride was very good even with 40 series tyres.
Old May 20th 2010, 20:23
Are there any recommendations for the maximum allowable G-force to stay in the "day to day comfort" range?
I've never had anyone tell me riding in my car would be described as comfortable, though it has been described as an "experience".
Maybe I should bolt up some 14"s with some 70% side profiles, but I still think comfort won't be a adjective to describe my driving! I'm a slave to car fashion I guess, bring on the 18"s!
Old May 21st 2010, 04:52
1303bug's Avatar
thanks guys for the great info , guess ill be going with 17" s found a nice pair of porsche doglegs (ttwists) , ill post pics up soon
Old May 23rd 2010, 06:12
Joel's Avatar
Joel Joel is offline
had 17s on mine for years too, ride is fine
even the 18s i used to have wern't too bad, just felt big bumps alot more with 35 series tyres
Old May 24th 2010, 07:28
evilC's Avatar
Just don't let anyone con you into thinking that ultra low profile tyres offer better grip or handling per se, if they did all the open wheel formula racers would be using them. The only time you will find low profile tyres on a racer is when ultra big brakes are required and that the tyres also have to fit under proscribed bodies leaving little room for tall(ish) sidewalls.
Tall sidewalls are also more tolerant to camber changes that is the bane of most street cars
Old May 25th 2010, 14:23
Exactly right. I love watching the slo-mos of F1 tires as they bounce back and forth with their tall sidewalls. There is talk about going with 18's on F1 cars with the 4 cylinder turbo engines, either way the tire manufacturers have their hands full.
A 50% sidewall seems like the best compromise, but the looks can suffer depending on what style you like.
Old May 26th 2010, 11:01
aircured's Avatar
aircured aircured is offline
can anyone recommend some 17" wheels and tyres for a novice like me.
just started in the scene and am still "green behind the ears".
Old May 26th 2010, 16:11
1303bug's Avatar
im with aircured on that one !
Old May 27th 2010, 10:29
aircured's Avatar
17"
what wheels were the 17's you have
'72 Type 1 - GT
'69 Type 2 - Bay
