Old July 31st 2010, 13:05
Rob's Avatar
Rob Rob is offline
Koni Reds Bumpstops
I cut down the bumpstops of my Koni front shocks 'cause I put on dropped spindles.
However, my tires stick out the fenders so at full compression the front fender is hitting the tire.
Anybody know what these bumpstops are made off ? I'm thinking I'll make some new ones. I assume you can't buy just the bumpstops ?
Old August 9th 2010, 08:34
evilC's Avatar
evilC evilC is offline
You should not have needed to do anything to the bumpstops if you used dropped spindle since the attitude of the damper is the same with/without dropped spindles. If you need new bumpstops check out your Koni dealer or althernatively use polyurethane bumpstops from one of the main suppliers - Superflex, Powerflex etc
Old August 11th 2010, 07:58
Rob's Avatar
Rob Rob is offline
Thanks Clive.
I'm running dropped spindles and an adjustable beam (belt and suspenders )
The really funny thing is that I'm probably close to stock height by now because of the way I set it up...
Anyways, the Koni shocks are pretty old, I bought them used, so I decided to pony up and ordered a set of KYB's.....
Rob.
