Old March 15th 2019, 18:12
Beetle E-brake to 944 cable adapter
Hi,
In the past, I made my own 944 adapter 'swans', but I got an official adapter set with a bunch of parts I bought in the past.
Its probably a Gerd Weiser set, sold by Franky's many moons ago.
The problem is: Iám not really sure how one is supposed to attach the beetle/VW cable into that adapter part?
Do you use solder that cable in? Or do you need to use a giant vise grip or something?
Thanks!
Walter
Old March 15th 2019, 18:54
flat flat is offline
They look like they should be crimped. Maybe take them to a store that makes hydraulic hoses and see if they can crimo them? Or DIY with a battery cable crimper...the kind that you hit with hammer?
I wouldnt trust solder
www.vdubengineering.com
Old March 16th 2019, 05:10
Yeah, I agree on that crimping is probably what is intended here.
However, I want/need to do the crimping on the car. Meaning not on the work bench. What hand held tool has enough power to do that?
Plus if it doesnt work, I have then a cut cable and a problem.
I think i’ll try to find some 4mm steel plate, make a new set of swans instead and leave the crimping to the more experienced metal workers among us ;-)
Old March 16th 2019, 16:15
Ok, so I made up some swan necks for the e/brake to work with the original handbrake cable and made up a new brake line for the caliper.
I did all this over 30 years for the first time on my first 1303 back then and I still think its an awesome upgrade to any IRS car
Old March 16th 2019, 17:52
H2OSB H2OSB is offline
Omg, Wally, I want the wheels on that notch.
H2OSB
johnL (aka H2OSB)
Old March 17th 2019, 04:47
And the best thing is: they weigh next to nothing!
Old March 17th 2019, 23:44
I know, I have one, so far. Lanner has a set of the even lighter ones!
H2OSB
johnL (aka H2OSB)
Old March 18th 2019, 04:03
AFAIK, there are no lighter ones. Even the versions with round holes (I presume that is the reference here?) weigh the same in the same width/size. I had one of those too and weighed both ;-)
Lots of hype (and $$) though with the Porsche 356 Outlaw crowd about the ones with the round holes...
These are still cheaper then original gas burners and about the same weight
Old March 18th 2019, 08:37
Well, I must admit I've never had a round hole spare in my hands, so I'll defer to you. They sure are more expensive on the used market.
H2OSB
johnL (aka H2OSB)
Old March 21st 2019, 07:27
Tzepesh Tzepesh is offline
Back to the topic: I have a similar e-brake adapter kit from Kerscher. I cut the bug end and crimped the new ends on the cables at a local machine shop. It's been working like this for more than 10 years now. Kerscher still has this kind of kit for sale.
Old March 21st 2019, 18:57
412STi's Avatar
412STi 412STi is offline
Hi Wally
If you have no way to crimp, then you can also solder the tail with silver solder.
Has ELO (Horst) also made and that keeps impeccable.
Question to you: What's up with kever.nl ?
Greetings Gerold
STi powered Typ4 in the works...
R.I.P. 1302/'72
Old March 22nd 2019, 03:25
Thanks for the tip!
At the moment I have made new 'swans' to operate the E-brake, so its all good and functioning now.
Keversite has been down for a few weeks now indeed. Such a pity, but I understood people are working on it. Lets hope its back asap.
