Old May 28th 2003, 23:33
rear sway bar on 944 suspension
any of you guys running 944 trailing arms and such, are you using a rear swaybar? if so, what are you using?
Old May 29th 2003, 04:29
Alex's Avatar
Alex Alex is offline
Porsche 944 rear swaybar
I have one left over.
Old May 29th 2003, 08:07
is there a difference between the NA and the Turbo ones? any mods needed?
Old May 29th 2003, 11:55
LOAF's Avatar
LOAF LOAF is offline
Swaybar
Alex,
I am mounting an 87 944 rear end.. and did not get the sway bar.. How much you asking.. Not sure how it would mount.. Can you provide a little guidance
also a
Old May 30th 2003, 10:56
Alex's Avatar
You have two choices:
You get the orignal Porsche sway bar mounts and weld them on to your torsion tube or you fab your own mount and save some money. You only need the mounts.....I have all the rest.
Will contact you when I get home.....I have someone already that might be interested.
The sway bar is 14mm in diameter.
Old May 30th 2003, 12:52
LOAF's Avatar
Sounds Good..
also a
Old June 15th 2003, 09:03
Tom Alltypes's Avatar
Tom Alltypes Tom Alltypes is offline
I just got done modifing my SAW adjustable spring plates to accept the 944 camber adjuster/sway bar link mount. That was a bit difficult. Burt the addition of the sway bar mounts was easy. I'll have pix on my site soon of what I did to my notch for this all to fit.
Tom Alltypes
Tom's Old VW Home
