Old March 18th 2003, 22:28
LOAF's Avatar
LOAF LOAF is offline
944 struts to 1303
I have read up on this but still a little confused..
I have a possible 87 model year front spindle complete with struts and everything that goes on the spindle..
I have a question.. Can I use these struts, I understand that I need to switch the top (hat) or mounts from my vw to make it work.. Can I run some tappered springs like from Top line to get the ride height I need and fit Porsche wheels up front.. (17x7.5)..
I am trying to save.. ALso due to the different year change on Porsche components I am thinking this may be a possible solution...
Will tappered springs fit ? or are they to narrow for porsche strut body.. How much will it lower the car with vw top stuff for the strut..
PLEASE HELP
also a
Old March 18th 2003, 23:30
Superman
The springs are larger on the 944 so the perch is bigger. The VW springs are too small to fit the Porsche perch. Yetibone did it but had to make some kind of clamp to hold the springs to the strut which is dangerous in my opinion.
Old March 19th 2003, 00:21
LOAF's Avatar
Superman thanks,
How about using porsche springs that are shorter.. i.e. Eibach prokit.. or something similiar.. I figure I would need something way softer.. Not sure of the spring rate on the SB.. But it would be stiffer than my stock but softer than porsche stock..
Foreseen problem...guess would be clearance of spring and wheel.. Maybe with spacers.. I would go with Flared fenders.. 1.5" or something.. Could I still use VW strut top to get a little lower and still be safe..
Sorry for incoherence.. Late and gotta go to work..(Me LAZY)
Any thoughts..
If anyone has info on the spindles that would be great.. Does anyone make a 19mm Balljoint vs the standard 17 that would have been needed if I had the right parts.. Still think its a 87 but who knows..
Thanks again
alex
also a
Old March 24th 2003, 08:14
Thanks again
alex
Yes, Kerscher in germany does. I've bought a pair.
I believe it is www.kerschertuning.de but the site is in German and that part is not mentioned on the site. I think Oliver Knuf can order them for you also.
Walter
