oil pump dimensions
I have an oil pump that was supplied to me as a 29mm pump. The inlet hole does not match up to the case 100%, so I will be moving it. I would just like to know if there is someone out there who has an oil pump lying around that may be able to help me with a simple dimension.
I need the distance from the mounting flange to the end of the pump gear boss and from the flange to the end of the pump gear tooth. By mounting flange, I mean the part which the case bolts fit through, where it meets the case not where the pump cover goes on. I basically need to face cut the flange 1.5mm but need to ensure that the cam insert still fits properly and does not push on the cam. Thanx a lot guys Tony Z
1969 VW aka Suicyde www.geocities.com/suicyde_vw Tony__Z@hotmail.com Last edited by Tony Z; March 24th 2003 at 14:23. |
