Old May 4th 2003, 13:06
LOAF's Avatar
LOAF LOAF is offline
1303 Strut options.. Research
I am in the process of the famous 944 brake swap.. started with a late conversion for the front but due to Strut issues found parts for an early conversion.. As I wait for the last of parts I am faced with issues.. as far as struts..
Based on my research.. here is what I have found and have questions on..
1) Maxxstrut.. about 400, all inclusive.. allows for Ride Height adjustment.. Depending on year from 3-5 inches.. These don't allow for any dampening changes.. Would like to now if can be rebuilt with a different insert or has to be TOPLINE only.. This would allow for a Strut insert with dampening adjustablility..
2) LA Performance.. about 380 Pounds equals roughly 500 bucks, maybe a little more.. This allows for ride height changes.. range unsure of.. As well as Dampening.. Needs orignal beetle parts for the Top Strut mount, believe.. Unsure of what name brand insert is used. Kinda expensive.. Not sure if progressive springs and if tappered..to fit larger widths under wings..
3) Kercher Strut.. Believe from GCC.. Can't read german but from peoples posts seems like they are as adjustable as LAP strut... Not sure if they are all inclusive, thus not requiring any of the old beetle parts.. (Top strut mount). Not sure if springs are tapered and if springs are progressive rate..
4) Utilizing superbeetle parts.. along with topline springs. Some strut inserts that are adjustable.. Would allow for dampening changes, but height set by size of spring..
My intent is to be able to change height due to different seasons that I may need to ride in.. as well as road conditions.. Also I want to participate in Xcross and would like to have the dampening adjustable to better tune the suspension.. Don't plan on winning but having safe fun.. along with learning more about suspension tweaking..
If anyone has info on above subject appreciate it.. along with by 78 vert..
also a
Old May 4th 2003, 17:02
juse's Avatar
juse juse is offline
If you are going to do drive autocross or anything where you might want to alter adjustments finely and quickly, then the best way is to obtain struts with 2 1/4" springs and threaded platforms.
I believe Kercher sell these, but you can make a pair of your own quite easily and much cheaper. Take a look of these done by Niko Niittymäki for his rallysprint 1302. http://www.geocities.com/aikakultaracing/tolpat.jpg
Justin
Old May 6th 2003, 09:37
LOAF's Avatar
Juse,
Thanks for the reply can you ellaborate further on what is required.. Any welding.. or is this a clamp on deal.
Also any one else have experience.. Please.
also a
Old May 7th 2003, 02:18
juse's Avatar
For the DIY coil-overstruts you need;
-bottom ends from the original struts
-a length of tube that has 2"OD and 2mm wall thickness
-a threaded tubekit for springplatforms
-Golf I/II inserts
-basic welding skills
-a friend that can machine you the fixing bits
All this needs only minor modifications and is quite straightforward task for a DIY mechanic, and the best thing is the low price of this all!
Justin
Old February 28th 2004, 01:21
Rjohnson009 Rjohnson009 is offline
Hi Justin,
From your description of the adjustable struts, sounds like you have done this before. My first question would be getting the parts. For my 72 super, I was leaning toward using the Civic spring kit from Vdubcustoms, but seeing you post, I am not considering going the route that you describe.
do you have any more details about where to get the parts in the parts list that you describe? I believe I could handle the welding with a few pictures to go by.
Any help is greatly appreciated.
Thanks,
Rick
Old February 28th 2004, 23:52
Jeza Jeza is offline
Rick
Minimal/ no welding required - check this link out for a description
http://www.superbeetlesonly.com/suspension/jjd.html
My lower stop (for the threaded body for the bottom spring platform) sits at the bottom of the strut- but then I've got a 350mm long spring - you may find yours fits differently.
Cheers
Jeremy
1302 RAt "GermanLook"
Old May 12th 2004, 00:56
Uber Affe's Avatar
Good Lord! I can't read! oh...it's german.
Can anyone make out that site at all?
I speak read and write 4 languages. None of them are german and I don't even know the $ exchange.
Does Kersher have an english version?
I have a 74 1303 in need of suspension.
Old May 12th 2004, 14:30
MattKab's Avatar
MattKab MattKab is offline
Try one of your languages here: 0049 8727 968812
Old May 7th 2003, 09:50
LOAF's Avatar
Spoke to Topline yesterday about their Maxxstrut...
From the conversation, he indicated that any Rabbit, or Golf insert could work with minor modification.. I assume then that some Koni with adjustable dampening could work.. This would allow me to get my project off the ground and when the time comes to either replace the insert from too many miles or time to hit the track comes, I can then switch to an adjustable insert..
Anyone know the estimated price for a set front and rear.. and a good location to get them.. for the future.. Has anyone put enough miles on their Maxxstruts and done the above.. How was the ride, and adjustablility..
Thanks..
also a
Old May 11th 2003, 06:19
Loaf
When I picked up my 944 brakes in the weekend, I also collected some adjustable 944 struts, only the lower spring platform is adjustable, the inserts look like they might be Koni sports. I belive someone here used these in a brake change/ suspension upgrade?
I'm still to figure out if it will all work, as I have to collect the bottom arms, then I can mock it all up and see if my ride height is good and suspension travel adequate.
But another alternative perhaps?
Jeremy
Old May 11th 2003, 21:14
LOAF's Avatar
Jeza..
Sounds great.. I have a couple of questions for you.. as far as which setup... I had 87 944 spindles that I was going to use.. Ended up not using them due to the following reasons..
-Lack of strut options.. LAP does have a set up that can be used.. I think its Type4boy.. Real nice guy.. and responded to my emails.. Also can use the 944 set up but spring rate is different and some issues with the top mount.. Can't remember exactly.. Plenty of guys here explained the reasons.. Just do a search.. for LOAF or Humble.. He was also doing this and completed..
Another issue was the speedo.. you can drill a hole but since I don't have access to any equipment..
Not to discourage if you have the parts.. I was going to go this route.. But Type4boy was on vacation and during the weekend that he was out.. I got anxious and started searching for other options.. I ended up finding a guy who would sell me 84 944 spindles and hubs for a $120.00 so I said hell with it..
If you are going with the earlier option.. Many choices.. LAP, Kerscher sell springs, and coilover.. and Topline.. Maxxstrut.. This is the option that I am going with.. From talking to them over the phone, very friendly.. I chose this for the height adj and the all in one package.. The other options you must retain the top strut mount assembly.. and a couple of other parts.. With the maxx, it also utilizes a modified rabbit/golf insert.. Not sure what modified means "per conversation with Topline" but figured it ment sawing something off.. to make it work.. This is good because down the road I can put Koni's and have not only height but damping adjusted.
Once I get these I will transfere the calipers and get them mounted on my vert.. Weather Pending..
Hope that helps..
It was tought finding info on the struts.. Many, many people have gone down these roads.. depends on time and money.
LAP setup was like 400 pounds.. Kesher was like 400-500 euro and maxx 400ish.. plus local, CONUS..
LOAF
also a
Old May 12th 2003, 05:38
My 944 brakes are from an 85 car. They are the single sliding calliper. I still personally think that these brakes are overkill for most beetles, but it is the easiest way to fit Porsche wheels and have a brake upgrade.
Most other options would cost similar amounts (for me esp being in NZ... a long way from a lot of the aftermarket parts) and not have the quality of braking or the ease of standard replacement parts.
Also the reason for me fabricating the struts/ using something existing. The freight and tax combined with the Pasific Peso increases the price enormously.
However this has bought in a whole lot of unknowns, as described above. Stuff I guess I'll only find out when it's bolted together.
All fun and games
Cheers
Jeremy
Old May 15th 2003, 12:45
MattKab's Avatar
Kerscher adjustable struts that have full range adjustable lower spring platforms. They come with Koni yellow bottom adjustable inserts. The earlier version had a helper spring but mine are the most recent, 80mm single, progressivley wound Eibach springs. Quality is amazing and the springrate feels perfect. Also uses VW Golf/951 strut bolts, one of which has eccentric washers for camber adjustment. Uses stock top bearing.
Worth every penny/cent/pfenig.
TUV approved which is the best bit
Matt
Pic is of the earlier 02/03 strut from the M7 site:
Old May 15th 2003, 13:11
MattKab's Avatar
It's an optical illusion that makes them look tapered, they are 8cm straight and have a progressive springrate.
Old May 15th 2003, 23:53
juse's Avatar
I bet those are the best you can buy for your Beetle, if you can afford...
Justin
