Old January 1st 2006, 16:42
GhiaBoy GhiaBoy is offline
Whats the widest tire you can go
whats the widest tire you can go with a narrowed axle beem
Old January 3rd 2006, 02:03
LLVWGL LLVWGL is offline
that will depend on a number of variables:
- How narrow of a beam?
- What type and year of car?
- Dropped spindles?
- wheel Offset?
- Do your brakes widen the track width?
- what type of wheels?
- How low is the car?
So, as you see there is no real answer to your (very General) question.
If the car is essentially stock then yes, you probably have room for wider tires.
The best way to find out is to look underneath for available clearance at full lock in each direction, and straight ahead. Also, keep in mind that you may want to have a friend sit on the front bumper to account for compression of the front suspension.
Good luck!
Old January 5th 2006, 19:18
speedy's Avatar
speedy speedy is offline
Smile
i have 17x7 et50 tyres on the front with a 2" narrowed beam and 22 mm of spacer and that fits under standard wings on a 67 if that is any help
jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
