Old July 15th 2006, 10:31
pantswagen pantswagen is offline
88turbo hub swap -to early -big to little disc
can i simply remove the wider hub from my 88 turbo arms
-and fit the hubs from a steel armed 924/44 or a 86?
-are they the same thing
they look it!!
Old July 15th 2006, 22:32
The extra track is cast in the ali arms. So the hub's wouldn't make a big difference. If the early hubs are shorter. Then you will have problems with e-brake shoes, and rotors lining up right.
Old July 28th 2006, 16:01
ya correct
-the steel arm hubs dont work
-good new is that the 86 alloy arm is the same as the 87 alloy arm
-the hubs are different -late is wider
early is narrower -but does look like the steel armed ones
-the splines are different
-anyway -the hub shaft is the same 85/6 alloy arm
-and 87 - alloy arm
-i just done fit the early hub to some late arms, -cos i didn't need the bump stop face
Old July 28th 2006, 16:22
here
late87 non abs 944 turbo arm
same width as 85 alloy turbo -with bump stop circle
-fitted with the 85 hub and the 87 stub axle
-fine splines - not bug splines- ylock axle shaft nut -no pin
Old July 28th 2006, 16:30
and so
the 'majic'
comes from the 1985 only fine splined hub, which looks like the steel armed hub -but isn't
-also the 1985 rear disc - if you check the listings, is a one year only affair, although the same diameter, the actual disc thickness is greater
Old July 28th 2006, 18:15
Talking so
spring plate to wheel face is 220mm
=8 and 3/4 inches -
easy get a 225 in then, maybe something bigger on a 53 et
10j?? 255???
-doubt it would fit
