no spark Y
ok guy this is driving me crazy I have tried 3 different DISTRIBUTOR nows
the stock one with ponits and then switched it to hi output electronic ignition and that didn't work then I BOUGHT a NEW distributor with the electronic ignition already installed and that didn't work then I just tried my grilfriends 009 from her 72 bug and that didn't work. so what's going on?? I have a 69 bug 1600 single port and I have power B4 the coil after the coil my everything has been looked over ten times it's all right no cut wires nothing that would not stop it from making SPARK and I'm stillnot getting it all new parts too so I just don't get it please help. Chris.
hi Chris first let go to the basic Ok
1- turn the ing on you have power on the + off the coil 2- Ck your firing order 1-4-3-2 3- try a new or a running coil 4- Ck your spark plugs ( used NGK ) bosh:disagree: |
hey brujo thanks for your help but I have tried all that B4 and tha's what's killing me it's soo simple but it's just not firing up it's turns over I have power on and off the coil all gronds have been checked I made sure that the dizzy is all the way down and clamped I even have a spark tool and it's shows nothing, I knwo the firing order it's TATOOED on me
hey, still no joy aye?. could be a bad live feed to the coil, you checked to see what voltage your getting when cranking? i'd try putting another wire in, just run one temporary, could even run it off of another battery just to check. just be carefull, must be loadsa fuel about if its not firing. good luck
hey thanks for your help I have tried a dumby wire too and I still got nothing I crank it over and I got my 12v B4 and after and I'v put a new Bosh coil on it too and still nothing I'm at the piont of just forking out the 250$ for a new wiring harness
