Old July 10th 2009, 19:12
72marinablue's Avatar
New wheels. Contemplating tires.
Hi everyone, I am about to take a step closer in getting my car where I want it but have a question. I am currently refurbishing these wheels and am going back and forth about what tire size I want to run. The fronts will be receiving 205/45 r16, But the rears i am going back and forth between 205/50r16 for the lower profile good looks, and 205/55r16 for the closer to stock gear ratio as I daily drive my car, a lot of which is on the freeway. Will I really notice the difference all that much between the two?
Wheel rebuild thread
http://forums.vwvortex.com/zerothread?id=4405645
1972 1300 GL In Progress
Old July 10th 2009, 20:34
cookvw's Avatar
cookvw cookvw is offline
givin you some props for some SICK wheels!
Old July 10th 2009, 21:04
Thanks!
Old July 11th 2009, 05:19
evilC's Avatar
evilC evilC is offline
Your speedo will be 9.2% out and will read higher by that proportion (great for bar stories) using the intended font tyres.
The rears will be marginally smaller or 5% smaller. The 50% aspect ratio will affect fuel consumption but I would doubt whether you will notice any accelleration benefit. Besides with the speedo that far out you might even surprise (fool) yourself. If fuel is not a big issue I would stay with the 50% aspect ratio as the slip angles as well as the cars stance will be better balanced front/rear
Old July 13th 2009, 20:12
petevw's Avatar
petevw petevw is offline
Go with the 205/50 like Clive said. It will looks proper with the 45's up front. Post some pics when you get them together. The 205's on those RS's look as though they will have some stretch.
'72 super
'65 bus
'52 split
Old July 18th 2009, 01:22
Just a lil bit in the back I ordered tires today. My work has a wholesale account through the tire-rack so I got some pirelli pzero nero M&S
