Old February 10th 2003, 12:05
wacks's Avatar
wacks wacks is offline
brake master cylinder qestion
need help guy's, im converting my brake system into a 4 wheel disc system im using stock vw calipers on front and 914 calipers with emergency brakes on the rear. my friend told me that the standard master cylinder could not supply the pistons of the caliper i am about to use? is this true? do i need to replace my present dual master brake cylinder? if ever, what shold i use? thanks
Old February 11th 2003, 18:08
NYBugman1972's Avatar
Im no expert, but I can share what I know.
I was looking to upgrade my 72 super's MC. Turns out it's a 19mm MC, which is an UPGRADE for 914's (17mm i think). So, I just went with a new german stock 19mm MC.
That's what I know.
Mike Serrone
///BrooklynAutoRennen
Old February 17th 2003, 16:41
Pillow's Avatar
Pillow Pillow is offline
I think a 911 unit would work well in that application. Usually 914s "upgraded" to the 911 MC especially when putting on BMW 320i front calipers.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old February 20th 2003, 18:31
Martice's Avatar
Martice Martice is offline
WAIT! ....I just saw this...
Are you saying that 320i calipers will work on the beetle stock disk/spindle?
Martin
PS:I've just started a new topic about calipers, you can post any info there.
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old February 21st 2003, 02:01
chigger chigger is offline
It really depends on whether the rears are floating cylinders or not. Basically a floating cylinder only has a cylinder on one side of the pad. A non floating cylinder has cylinders on both sides of the pad. A floating cylinder requires alot more fluid before it reaches the rotor. Therefore a larger diameter MC. Unfortunately the larger MC requires more petal pressure due to a less desirable mechanical advantage. A major reason most floating systems have vaccuum assist. With a dual pot front and a dual pot rear the stock dual circuit MC should work fine.
The 914 people use a 320i caliper on the front as an upgrade. It is susposed to bolt right up. I just don't know it the caliper bolt pattern is the same as the bug bolt pattern. Some one with both needs to clarify this once and for all.
Hope this helps.
