Old November 4th 2003, 23:51
Pillow's Avatar
Pillow Pillow is offline
To do. To do! To do!!! %&#(*^#(
Oh my the list to be accomplished IF this bus is ready for Tampa.
- 2 tires for the rears
- Weld in and allign rear control arm mounts. Not easy at all!
- find two eccentric bolts for the 944 arms swingplate adjusters. (burried somewhere I think in the basement)
- Junkyard for a good pass heat exchanger and rear IRS bearing spacer.
- Tune engine and carbs.
- Unsure on the exact needs for the emergency brakes. Custom for sure.
The good:
- Tranny ready for action.
- Axles ready and T2 CVs.
- All the little stuff there and ready minus the 3 little things above. Tires I do not see as an issue at all.
Additional work needed later:
- new front tie rod ends.
- allignment on a professional machine for front and rear.
- Heater cables installed.
Arg is this fun? Sick I tell you!
Later,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old November 5th 2003, 00:15
you don't even want to see my list just to be able to trailer it and push it onto the grounds. no way in hell it is going to be running. we will be having a build party saturday though and probably sunday at the show.
Old November 5th 2003, 02:14
Massive Type IV's Avatar
Don'yt you guys gett too worried about making the show......Haste makes waste and breaks parts and engines!
Jake Raby
Old November 5th 2003, 10:44
vujade's Avatar
vujade vujade is offline
You'll make it Pillow.
Good to see you btw
WinterJam 2010
Old November 5th 2003, 18:21
Howdy Stranger
Old November 6th 2003, 00:17
Pillow's Avatar
Update.
No go on the '66 Too much to do still. And as Jake was saying, do it once and do it right even if it takes a while.
Good news is that I am bumming a '71 Westi to get there Little Susan and myself will be there! Yeah!
Oh and yes it is good to be back at home and able to work on the VW again... 6 weeks away only gives the fingernails enough time to clean the grease out from under them!
Take Care,
Adrian Pillow
