Old April 22nd 2004, 16:26
drew23's Avatar
drew23 drew23 is offline
Dual Weber Jetting Question
My buddy has a Type IV with an upright conversion in his beetle. He currently has a set of built heads on it but is going to switch to stock due to a problem with the existing heads. It has a mild cam if it makes a difference. What main and idle size would be close to what he needs? As long as you can give me an idea of were to start from.
Thanks,
Justin
A pipe gives a wise man time to think,
and a fool something to stick in his mouth.
Old May 11th 2004, 16:39
I looked at a book i got for weber carbs and i found this on a production jetting table:
twin 44mm idf 2000cc, 36mm (venturi), 4.5 (aux.venturi), F11 (emulsion tube),
1.15 (main jet), 1.70 (air correction jet), 0.50 (idle jet), o.55 (pump jet), 1.75 (needle valve).
I hope this helps
Aircooled 4ever
1973 1303 going towards GL
