Old October 14th 2002, 15:41
MattKab's Avatar
MattKab MattKab is offline
Rear wheel drive speedo
Any suggestions on how a speedo cable could be driven by the rear axle? Perhaps 1:1 gearing from the output flange.
I'm running 215/40ZR17 upfront (596mm) and the correct ~636mm diameter at the rear using 225/45ZR17.
Any ideas?
Matt
Old October 15th 2002, 01:57
Andy White's Avatar
Andy White Andy White is offline
Hi Matt,
You could always just get the speedo recalibrated for the new O.D.
Regards,
Andy
'55 oval GL
944T Calipers and discs front & rear.
17" Turbo rims 205/40 front, 215/45
rears
230BHP TIV fuel injected.
IRS+Berg 5 speed box.
Build in progress.
Old October 15th 2002, 09:02
The new VDO speedos use an impulse from a sender, you could stick some magnets on your cv to produce an impulse for the speedo.
Steve C
Old October 15th 2002, 13:39
MattKab's Avatar
Smile
Can the speedo be recalibrated?
I would like to use my stock speedo, as anything else looks odd in the 1303 'hole.
I'll check the VDO website.
Thanks,
Anymore ideas?
Old October 15th 2002, 18:16
kdanie kdanie is offline
Most speedometer shops can set up a small gearbox to change the ratio to correct for different tire sizes. Not a big deal, it just fits between the speedo and the cable.
ken
