Old March 9th 2005, 01:23
ericglooker ericglooker is offline
non Porsche brakes
Are there any other brakes other than VW or Porsche that will fit with minimum amount of modification/fabrication? Preferably ricer type brakes, I am planning on putting on Motegi Track-lite wheels.
Old March 9th 2005, 12:13
try http://www.vdubcustoms.com Talk to Lanner, he can give you some options.
Old March 10th 2005, 01:25
Ok Thanks Ill check it out
Old March 14th 2005, 17:06
Al B Al B is offline
I've put BMW M3 stuff on mine.........
not easy but worth the effort ('Had to use BMW discs as my wheels are BMW stud pattern and I aint changing them!)
I'm using a Porsche 944 split master cylinder with these as the pedal travel with the stock Bug one was sooooooooooooooooo long!!!
Much much better now.
'Any questions feel free to ask.
Al B
Old March 17th 2005, 00:59
Nice work with the M5 Brakes! :agree: What it the stud pattern on them?
Old March 17th 2005, 01:01
M3 brakes, my bad any way they look awsome!!!
Old March 17th 2005, 04:33
Hi, the stud pattern is 5 x 120 .......... BMW specific only I'm led to believe
Theses are the rims....... which I'm not changing!
Al B
Old March 26th 2005, 22:47
rip's Avatar
rip rip is offline
Al B
how did you attach the rotors? did you use porsche hubs?
thanks
rip
Old March 27th 2005, 06:56
Originally Posted by rip
Al B
thanks
rip
Nope, I made my own hubs up out of the bug discs and drums. (they were blank THICK items that were already drilled to BMW stud pattern)
The rear drum was turned down so that the disc fitted over it, 'Top Hat' style. Then bolted to the hub with countersunk screws and a bottle of threadlock!
heres the rear hub,
With the fronts I again turned down the bug discs to make a similar hub, but instead of fixing the disc ofvr the top I attatched it to the back again using the 5 screw method, you can see it better in the pic...
Al B
Old June 18th 2005, 16:21
Daggis Daggis is offline
Do you have any pictures from the backside of those brakes? Would be fun to see how those caliper brackets look..
Old June 22nd 2005, 16:40
Sorry mate not yet, I'll endeavour to get some over the next few days...... week.
Al B
Old June 23rd 2005, 01:44
Sweet. Thanks man.
